Author Topic: What Forking Oil?  (Read 2453 times)
Offline Guilly
Re: What Forking Oil?
« Reply #10 on: October 02, 2009, 06:50:12 PM »
I just did the forks on my 250k- The manual says they should have around 570ml /side I got a total of 600 odd out of both forks. Ive always used ATF-- put 10psi a side -- $11/litre they feel fine to me  :D
"Give me fuel give me fire give me all that I desire!'
BSA Bantam 125
Vespa
Kawasaki 100  10 spd trail boss
XL 250
DT175A
DT360A
Ducati Sebring 350
XV750 Yam
Current
IT 250J
IT 250K
Yamaha FZ600
Offline rosey250
  • Me n Barbie
« Reply #11 on: November 15, 2015, 05:23:46 PM »
Just did my 250k forks with 10w oil at 170mm from the top of the sliders with no spring - as per manual.
And I thought the forks would be almost the same as Barbie as they are both 43mm , but where Barbie had a normal bolt to the dampening rod the 250k had a bolt with holes and an internal spring? What is this for?
Major sponsor - Echuca Mazda BT-50
« Reply #12 on: November 15, 2015, 05:39:21 PM »
There is a rubber bung right below the bottom of the hex in those bolts Rosey and that is the compression adjuster. Straight slotted screw.
http://www.yamahait.com.au/forum/index.php/topic,18367.msg159705.html#msg159705
Offline rosey250
  • Me n Barbie
« Reply #13 on: November 15, 2015, 09:57:32 PM »
Thanks Fred .
Would there be any advantage in putting the compression adjuster bolt in Barbie's forks? That's if they would screw in of course, and I think the fork legs are different
« Reply #14 on: November 16, 2015, 07:07:16 AM »
If I had to guess, I would say they wouldn't fit, because the damper rods would be different as well as the fork slider.
Offline rosey250
  • Me n Barbie
« Reply #15 on: November 16, 2015, 07:48:20 AM »
I concur , sir!  No need to fcuk with something to get unknown results for an unknown amount of money!
I will save my bikkies for gold valves, new springs, and new bushes - proven and tested 'bits'
