Author Topic: jumping out of gear  (Read 783 times)
Offline pinemarten
jumping out of gear
« on: June 02, 2010, 07:24:38 AM »
hi guys ,got the bike running tonight and it was flying ,unfortunately it would suddenly jump out of gear  as the revs got higher ,this didn't happen all the time ,and at low revs it seemed alright ,any suggestions or is it a case of a new clutch
Re: jumping out of gear
« Reply #1 on: June 02, 2010, 07:37:12 AM »
My guess is the gear dogs are worn,you can get them back cut at a machine shop,for half the price of new gears,if you can still get them.
What's happening is ,as the power comes on, the gears want to spread apart,because the gear dogs have worn a ramp,so as to speak.
Take them to a machine shop,get them to back cut the dogs a little and you will be good to go.
Or your shift forks are getting worn.But my guess would be worn dogs.
« Reply #2 on: June 03, 2010, 05:25:42 AM »
Good advice.
Before you pull the engine apart check the gear change mechanism that lives inside the clutch cover.
Definatly not a clutch issue.
Dave R
« Reply #3 on: June 03, 2010, 05:34:38 AM »
Check out items 2,3,4,5,24,26,27,28.
Check items 1,2, and 3.
Number 14 is a plastic spacer that fits next to the gear lever and stops the change shaft moving too far. It may be missing and cause poor shifting between gears.
Dave R
Offline pinemarten
« Reply #4 on: June 03, 2010, 07:25:23 AM »
thanks for the info ,will investigate further and hope its something simple and cheap .
