Yamaha IT Australia
July 30, 2010, 01:20:44 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Yamaha IT Australia - The place that Yamaha 2-Stroke enthusiasts call home!
   Home   YITA VINDURO Recent Topics Login Register
Pages: [1]   Go Down
  Print
Author Topic: Crank case assembly question no 2!  (Read 158 times)
Devondan
Yama-Legend
Offline Offline
United Kingdom United Kingdom
Activity
10.56%
« on: February 21, 2010, 12:56:20 AM »
Ok I'm getting nearer the time when the two halves of the yz are going together   Grin Grin  So ... firstly what sealant is favourite for the cases that can be bought over the counter? I used to use Hermatite in my yoof,  green I think?
and I am told that Yamaha always sold cases seperately, ie they werent matched pairs, am I likely to have any difficulty fitting a rightside case off a different bike?  The original may be repairable but the main bearing housing is very lose and the case has a crack, so a swap is easier and cheaper as I have one!
Thanks in advance
Logged
Denzlepob
Yama-God
Offline Offline
Bangladesh Bangladesh
Location: Heaven with 1 virgin left and I'm saving her for Kato's birthday party.....
Activity
100%
"I've jihad enough"
WWW
« Reply #1 on: February 21, 2010, 04:04:51 AM »
I've missmatched cases, no Probs on Yamaha's, you can use bearing lock on the mains if you are worried, I used blue Hylomar from Ebay http://cgi..._540wt_859
Got any pics?
Denz
Logged
So after school I take a dip in the pool which is really off the wall, I got a colour TV so I can see the Nicks playing basketball, hear me talking about cheque book, credit card more money than a sucker could ever spend..........
Devondan
Yama-Legend
Offline Offline
Activity
10.56%
« Reply #2 on: February 21, 2010, 04:30:08 AM »
Its not very clear but there is nearly 1mm play on the main bearing housing (both laterally and rotationally) and about a half a mm on the clutch bearing seat, so I'll continue with plan A and swap cases, what sealant do you use between the two cases?  Someone mentioned Honda bond but I cant get that.
Logged
Evan
Yama-Hero
Offline Offline
Canada Canada
Activity
1.67%
« Reply #3 on: February 21, 2010, 07:19:27 AM »
This is what i use. http://www...ealant.htm
Logged
1986 Yamaha IT200S
1984 Yamaha IT200L "The Pit"
1984 Yamaha XS650 Heritage Special
1993 Honda Z50R - Stuck In Third!
F.Gassit
Yama-God
Offline Offline
Australia Australia
Activity
100%
WATCHAFUGGIN LOOGINAT YACAHNS!?
« Reply #4 on: February 21, 2010, 07:55:55 AM »
1mm sounds alot..................if it were me, I would look at some .5 mm shim stock, cut to size and fitted betweem the case and bearing to take up slack. Use bearing lock to stick the shim paper to the case, not the bearing.
I do the same as this on my wheel hubs when they are out of tolerance...............still going strong.
Three-Bond silastic for sealant is good..............but there are many brands of sealant that will work in this application
Logged
I MISS BOB...............AND BB'S MONKEY PORN.
Martin I Henry
MODERATOR
Yama-God
Offline Offline
Activity
100%
WANTED 1981 IT125 www.yamaha-it.co.uk
WWW
« Reply #5 on: February 21, 2010, 08:12:27 AM »
  I take it that the bearing housing itself is moving within the crankcase.
  This is a common problem and one that can be a real pain to sort.
  My IT175E had this happen on one side, and the YZ125E it was really bad on both.
  I got Steve Riley ( no relation ) of Piston Broke in Bristol to bore the cases to accept a larger OD bearing that he sourced from somewhere. This did away with the pathetic cast in housings. Personally I prefer the Honda 4T small single main bearing housings, they are cast in like the Yamahas but made from cast iron and you can fit a crank without having to warm the cases or use a puller.
    Don't throw away those worn cases yet, they may come in usesful in the future !!
   The DT175 uses very similar cases to my YZ and IT yet the bearings sit directly into the crankcase without the cast in housings. ' More better ' as the yolkels say at work !!
   Oh, I have also used unmatched cases on a number of brands over the Years.
    Dave R
Logged
The only thing that's different is me; I've become bitter, and let's face it, crazy over the years. And once I'm swept into office, I'll sell our children's organs to zoos for meat, and I'll go into people's houses at night and wreck up the place. Muahahaha!
Richard Nixon's head, Year 3008.
F.Gassit
Yama-God
Offline Offline
Australia Australia
Activity
100%
« Reply #6 on: February 21, 2010, 08:50:52 AM »
Oh, I thought he meant the bearings were a loose fit......................my mistake. Tongue Roll Eyes
Logged
Griffo
MODERATOR
Yama-God
Offline Offline
Australia Australia
Activity
27.22%
« Reply #7 on: February 21, 2010, 09:29:10 AM »
Yamaha use 3bond Liquid gasket Grey. The tube is a maroon ish colour. I can't remember the exact number...
Logged
IT465H, IT465H, IT465H and a DS80
killindini1
Yama-Hero
Offline Offline
New Zealand New Zealand
Activity
59.44%
IT200N,IT200L .Wanted:IT200S Member 269
« Reply #8 on: February 21, 2010, 10:39:09 AM »
Yamabond 4,from your local Yamaha dealer.
Logged
Devondan
Yama-Legend
Offline Offline
Activity
10.56%
« Reply #9 on: February 22, 2010, 03:48:41 AM »
This one?   http://www...Three-Bond
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
