Yamaha IT Australia
July 30, 2010, 01:39:14 PM *
Welcome, Guest. Please login or register.
Login with username, password and session length
News: Yamaha IT Australia - The place that Yamaha 2-Stroke enthusiasts call home!
   Home   YITA VINDURO Recent Topics Login Register
Pages: [1]   Go Down
  Print
Author Topic: How to clean your rusty nuts...................  (Read 143 times)
fatterhatter
Yama-Hero
Offline Offline
United Kingdom United Kingdom
Activity
23.89%
'77 it400 81 dt250 85 yz490 harris Z1B mz trophy
« on: February 05, 2010, 05:39:55 AM »
pinched of the web  Shocked Shocked
Step 1: Acquire some dangerous chemicals*
(*they're not actually all that dangerous at all)
What you need is Oxalic Acid Crystals. They're most commonly used diluted with water to bleach or remove stains from wooden floors. I get mine from http://www...care.co.uk for about £41 for a 10Kg tub like this:
Step 2: Measure out the crystals & add some water
In this example I used 500g of crystals to make up about 45 litres of de-rusting solution. Plastic buckets make good containers for smaller components but as I was attempting to de-rust a cyclinder head, I went for a nice big platic packing crate:
Step 3: Stir up some trouble!
Keep your face out of the steam that comes off as you add the hot water.
This is really important.
It's not that the acid will eat your flesh or anything like that - it just irritates the skin and makes your throat sore. Use a long stick and stir the solution until all the crystals have dissolved:
Step 4: Dunk your junk
Gently lower your chosen rusty junk (erm...I mean your cherished hot rod components!) into the solution. Now is a good time to think about how you're going to retrieve them from the murky depths in about an hour! The solution won't have any effect on plastic so plastic washing line is good for smaller parts and nylon rope works for heavier bits. I used some old speaker cable for the heavy Pontiac cylinder head in the photo:
Step 5: Add more water
At this point, add just enough hot water to cover the parts you want to de-rust. No point in diluting the solution unnecessarily. Try to ensure that no air bubbles get trapped under or inside anything you're de-rusting. With regard to the ratio of crystals to water - I usally work it out so that the ratio goes no lower than 100g of Oxalic Acid crystals for every 10 litres of hot water.
Step 6: Don't fiddle with it!
As the acid gets to work on the parts it's important not to fiddle with it too much. The acid reacts with the Iron oxide and it ends up suspended in the solution as bright yellow particles. Eventually, these particles sink to form a yellow sludge at the bottom of the container. Even after a number of uses, the solution will still remain active but disturbing the sludge can leave a yellow greasy film on your parts (not nice!) so try to resist the temptation to poke your parts!
After about an hour, your solution will probably look something like this:
Step 6: Get your bits out
This is where you wish you'd read Step 4 properly and thought about how you were going to retrieve your stuff from the bottom of a container full of acid! Assuming you're smarter than I was when I first tried this, you'll be able to rescue your stuff no problem. Luckily - I'm smarter than I used to be:
Step 7: Bask in the glory of your new found chemistry skills!
A quick rinse with cold water will neutralise any remaining solution on the parts you just dipped. Now would be a good time to sit back with a cuppa/beer/fruit herbal infusion (your choice!) and admire your achievement (especially if you have an identical untreated part to compare it with):
Here's a bit more info about Oxalic Acid:
It has no effect on the base material. You could leave an item in the tank for months and it wouldn't corrode.
It has no effect on paint. This is really useful if you want to retain original paintwork on an item that has started to rust in places. The paint remains untouched.
It has no effect on chrome. Again, really useful for removing the rust ingrained in any pitting - it's surprising how much better an old chrime item can look after this treatment, even when the pitting remains.
You can legally dispose of old solution down a drain, as long as it's diluted well.
If you water rhubarb with diluted Oxalic Acid, it will become extemely toxic and can be fatal if eaten!
Chemical safety info about Oxalic Acid can be found here: http://ptc..._acid.html
 ;)oxalic acid is the active bit in vinegar Wink
but you can get cheap of ebay.......
http://www...-bath.html
it leaves my nuts nice and shiny and saves replating costs Grin
Logged
Denzlepob
Yama-God
Offline Offline
Bangladesh Bangladesh
Location: Heaven with 1 virgin left and I'm saving her for Kato's birthday party.....
Activity
100%
"I've jihad enough"
WWW
« Reply #1 on: February 05, 2010, 06:13:23 AM »
I think we would all like to see a picture of your shiny nuts.  Wink
Logged
So after school I take a dip in the pool which is really off the wall, I got a colour TV so I can see the Nicks playing basketball, hear me talking about cheque book, credit card more money than a sucker could ever spend..........
fatterhatter
Yama-Hero
Offline Offline
Activity
23.89%
« Reply #2 on: February 05, 2010, 06:18:36 AM »
 Grin unfortunately my shiny nuts are very small and difficult to picture Shocked Shocked
and some more results
http://www...-it-is-one
better than jenolite / phosheric acid that changes the rust black
Logged
Pages: [1]   Go Up
  Print
Jump to:
Powered by MySQL Powered by PHP Powered by SMF 1.1.11 | SMF © 2006-2009, Simple Machines LLC Valid XHTML 1.0! Valid CSS!
