Author Topic: It will be back..  (Read 3173 times)
Offline fatterhatter
  • 7
Re: It will be back..
« Reply #20 on: February 26, 2011, 12:10:24 AM »
very nice ;D
« Reply #21 on: February 26, 2011, 12:27:13 AM »
 8) 8)
Looking good!!!
Cheers!
Leslie
Online sweede490
« Reply #22 on: February 26, 2011, 08:42:28 AM »
 Looks great Stu , nice work   ;D
    Muzz
Offline oldbiker
« Reply #23 on: February 26, 2011, 10:56:37 AM »
thanks. I was going to 2-pak the frame, but good 'ol rattle cans won out this time just in case I have to touch up the paint after a scrape. It probably wont look this good at the Muster as I have a trial the weekend before.
Stand up you fool!
Offline oldbiker
« Reply #24 on: June 26, 2011, 08:22:13 PM »
more updates..
The Falcon Shocks are the best thing Ive put on it for ages. The wider footpegs help with the tighter sections around rocks and over logs etc..I've had the flywheel weight shaved, front suspension has 35mm spacers in there now(down from 55mm), the brakes actually work and a carby sort out as well. It now rides very well and I have had to adjust my riding to suit. The reduced weight on the flywheel makes it nice and snappy off idle.
At the end of the years comp, I'll be putting in a new piston and rings.
Stand up you fool!
