Author Topic: Swingarm paint  (Read 123 times)
Online gearhead86
Swingarm paint
« on: May 20, 2019, 12:36:29 AM »
I have just painted the swingarm for my new (to me) DT125LC. I used duplicolor's color match automotive paint. I'm wondering what others have used and wither or not it held up to abuse.
My preperation: I just sandblasted and then wiped down with a dry, fresh rag. I then applied the color coat direct to metal, 4 coats.
It looks pretty good but I suspect it won't last long. The paint used is a lacquer. Duplicolor's site says to use a primer, I didn't.
Im trying to decide if I sandblast again and repaint. Should I use the same paint just with a primer or a completely different type of paint.
I'm from Canada eh.
Re: Swingarm paint
« Reply #1 on: May 20, 2019, 05:41:44 PM »
I use an epoxy enamel anti rust metal paint in an aerosol can, in Australia the trade names are Killrust or Rustgard.
On a steel frame or swingarm I use them without primer as per the makers recommendation, it sticks better than when you use the primer for some reason. On aluminium I use an etch primer first.
