Author Topic: Yamaha IT175H. 3R6 US Model. The 12v DC Conversion Thread.  (Read 1502 times)
Over the next few weeks or possibly years I will document the thrilling conversion from a paltry 6v to the astounding 12v.
Expect mega volts, amps and watts and possibly a bit of fire as well !..... Or more likely, not.
Some of the stuff I am using:
Re: Yamaha IT175H. The 12v DC Conversion Thread.
« Reply #1 on: May 17, 2019, 04:07:11 AM »
One of the things we need to do is get the flywheel off the crankshaft.
This one was a bit stubborn, as it had never been removed before. However, one of the IT Facebook groups has some invaluable advice which I cheerfully tried:
No luck, more leverage required:
Okay, that was clearly a failure, let's try something more professional:
The slow moving .45 230g projectile failed to do the job, perhaps a sustained burst of 9mm will do the work required:
Not happening..... As a last resort, I used an M27x1 L/H thread flywheel removing tool and funnily enough, it did the job:
All the nuts, bolts and washers were tossed into a tub and allowed to mix freely with UNF, UNC, Whitworth and BA alternatives:
« Reply #2 on: May 17, 2019, 04:11:05 AM »
Next, I had fun unplugging the stator wires from the loom:
The PVC insulation covers had welded themselves together sometime over the past 37 years and the connectors were a real bear to separate.
Some remedial repairs needed.
« Reply #3 on: May 17, 2019, 04:21:38 AM »
The stator plate surrendered after being poked with a blunt knife:
The screwdriver blade points to the earth tag of the lighting coil:
The M4x30 screw was a pain to remove. Some alloy came out with the fastener so the female thread will need a bit of work #cheesealloy:
Take your 1950's ex MOD wire cutters and remove the tag:
« Reply #4 on: May 17, 2019, 04:30:05 AM »
Find some insulated wire and push it cheerfully down the black PVC sheath:
The black rubber grommet that seals on the flywheel cover had a blanked off position for the wire to pass through:
Clamp the additional wire using the original bracketry:
I found some black glassfibre heat resisting tube on an old kettle in the scrap skip at work to copy what Yamaha did with the other wires from the other coils:
?? Now to find the soldering iron!
« Reply #5 on: May 17, 2019, 07:33:19 AM »
Made name giggle, nice work btw!
Offline DynoTronix
« Reply #6 on: May 17, 2019, 10:05:02 AM »
Can't wait to see how this turns out.
BTW, nice work, Dave.
« Reply #7 on: May 17, 2019, 02:41:44 PM »
Super stuff dave ! coming along nicely
Shorts
« Reply #8 on: May 18, 2019, 05:29:29 AM »
Love the fine selection of removal tools you have in your arsenal Dave ;D
Nice Work, normal bulbs, or led?
« Reply #9 on: May 18, 2019, 06:33:22 PM »
A box of 10 of  China's finest 12v 35/35 for the price of one from a dealer.
