Author Topic: Broken Transmission Drain Bolt  (Read 273 times)
Offline froidy
« on: May 13, 2019, 07:34:52 PM »
Hi guys, apologies for multiple posts on the forum. Just realised this is the correct area I should have posted originally.
I am a complete idiot and have managed to overtighten and break the tranmission oil drain bolt on my 92 WR200. Anybody ever done this before that may be able to offer advice?
It's a fairly long bolt and the bit that snapped is the very end where the thread is so it's a fair way in. the rest of the bolt (about 64mm of it) has come back out, leaving the bit way down in the thread. I know I'm in deep sh_t. Any help appreciated! Thanks in advance. (I have a torque wrench on the way as I obviously need one)
Offline froidy
Re: Broken Transmission Drain Bolt
« Reply #1 on: May 13, 2019, 07:35:51 PM »
20190512-214350-resized" border="0
Offline Fixitandy
« Reply #2 on: May 18, 2019, 02:26:33 PM »
Hi mate, if you can get at least 2.5-3 threads if purchase on the bolt, just clean up the end so it?s flat & proceed as normal, that bolt is part of the side cover fixing arrangement but as long as it doesn?t leak at the drain point, all good, just clean both surfaces(drain point & copper washer) with solvent/cleaner a little blue loctite, just nip it up, ride & check, if no leaks, job done. If that doesn?t work you?ve got no alternative to stripping it down on that side till you can drill & easy out. Let me know how it goes? Cheers Andy.
Offline froidy
« Reply #3 on: May 19, 2019, 11:12:38 PM »
Thanks Andy!
Will certainly try that first and keep you posted! Cheers
Sent from my SM-N960F using Tapatalk
Offline Fixitandy
« Reply #4 on: June 16, 2019, 09:12:08 AM »
Thanks Andy!
Hi croustade, how did you get in with the drain bolt? Andy.
