Author Topic: Best way to flush cooling system.  (Read 197 times)
Offline Fixitandy
« on: January 08, 2019, 08:23:51 PM »
Hey fellow members, just after your thoughts on the best way to flush my cooling system? Cheers Andy.
Re: Best way to flush cooling system.
« Reply #1 on: January 08, 2019, 09:08:23 PM »
On my ITs I use a garden hose then run it a bit to dry the cooling fins out.
« Reply #2 on: January 09, 2019, 01:56:32 AM »
Drain system completely. Fill with distilled water. Start and allow to reach temperature. Allow to cool and drain. Repeat. Refill with proper coolant being sure to belled any air. Running to temperature allows it to flush areas unreachable by other methods and can loosen any scale stuck to internals.
Offline Fixitandy
« Reply #3 on: January 09, 2019, 10:24:39 PM »
[/quote Thanks Rexxy, will give it a lash. Cheers Andy.
