Author Topic: Oil Pump/Auto Lube  (Read 1211 times)
Re: Oil Pump/Auto Lube
« Reply #20 on: April 29, 2019, 08:13:37 PM »
Only problem I see with the Motul ester based oils is the headaches and nausea you get when following someone using it. May have been a bit hungover too though.
« Reply #21 on: April 30, 2019, 07:38:26 AM »
Hey guys,
What oil are people using fo their DT?s with the autolube still in action?
There are lots of different brands of 2 stroke oil out there and they all have diffferent premix ratios. So how do you decide which oil??
Firstly make sure it ok for oil injection systems keep in mind some oils are a bit thick , even tho they 2T oils, and omly designed for ptemix.
Offline Danfr
« Reply #22 on: May 01, 2019, 12:44:51 PM »
After reading many reviews, I picked up the Motel 710.
Anyone who has or is considering running the stock oil pump should definitely watch this video!!
It perfectly explains how the pump works. It gives you a better understanding of how the pump changes with thottle and RPM separately. After watching the video, I had a look at the pumps 'ramp' or 'cam' and you can see that how much is pumped out doesn't change after a certain point in your throttle. At a certain point the ramp flatlines and so the volume pumped does not change.
I would highly recommend the video!!
Offline Glenngt750
« Reply #23 on: May 05, 2019, 10:11:38 AM »
I think that is my favorite, Motul 710. Very little smoke once warmed up. Ester based oil is the best of the best, when it comes to synthetic oil.
« Reply #24 on: May 05, 2019, 07:20:18 PM »
That was a brilliant vidjeo about the pumps. Never been enthused enough to delve into them, but excellent descriptions.
