Author Topic: Will a YZ490 1982 clutch basket fit a IT465j 1982  (Read 338 times)
Offline Dean5838
« on: December 19, 2018, 12:24:30 PM »
Hi All,
Need a new clutch basket for my IT465J 1982.
Will a YZ 490 1982 fit the same?
Re: Will a YZ490 1982 clutch basket fit a IT465j 1982
« Reply #1 on: December 19, 2018, 08:15:20 PM »
yes/no
no it won't go straight on. helical cut vs straight cut gears
but...
if you get the primary gear on the crank to match the basket, and you will need the later friction plates as they are different too. the centre hub and outer plate is the same though.
Offline storie585
« Reply #2 on: December 19, 2018, 10:42:56 PM »
Not a hard conversion. I did it on a YZ 465.
« Reply #3 on: December 20, 2018, 08:49:02 AM »
yeah both my 465's are combinations of parts. straight forward if you have everything. if you find a basket for sale get the crank gear to go with it, and remember which clutch plates you need when you order new ones ;)
Offline Dean5838
« Reply #4 on: December 20, 2018, 10:32:07 AM »
Thanks all.
What if I just take the basket off the primary gear and put it on the existing primary gear I have in the IT465.
Is it then just a case of getting the right clutch plates?
I have done the same on an RD350LC before.
I am sure I could get the rivetts needed from somewhere.
The issue I have is one finger is broken on the existing basket.
« Reply #5 on: December 20, 2018, 05:53:32 PM »
yeah can be rivetted back together, I have one that I rebuilt from pieces for much the same reasons
I'm just not 100% certain the rivet holes are in the same spot to the later basket. that would be the only reason that would stop you.
when I did one it was an earlier basket that had the same part number cast into it, earlier 400 I think but it was an orphan basket of unknown origin. went back together with new rivets easy.
« Reply #6 on: December 20, 2018, 05:54:55 PM »
got any pics of the RD?
 8)
Offline Dean5838
« Reply #7 on: December 21, 2018, 12:36:20 AM »
Pic of each
« Reply #8 on: December 21, 2018, 11:23:02 PM »
superb bikes!  8)
