Author Topic: Dt250B replacing steering head bearings?  (Read 319 times)
Offline topari
« on: November 20, 2018, 01:06:10 AM »
My DT250 uses ball bearing top and bottom in the triple clamps. Unless I am mistaken the aftermarket kits use tapered roller bearings. Am I correct in this?
Here is a typical ebay set.
Re: Dt250B replacing steering head bearings?
« Reply #1 on: November 20, 2018, 08:00:03 AM »
I have a dt2, pretty sure same in this regard. It has a tapered roller kit in it from a previous owner.
« Reply #2 on: November 20, 2018, 08:21:22 AM »
I've used that type of taper roller kit on my DT175 and it worked just fine.
The thickness of the bearings was a couple of mm different making the top yoke sit a bit higher than normal but it was all good.
