Author Topic: IT250J OEM silencer, what's inside?  (Read 1601 times)
Re: IT250J OEM silencer, what's inside?
« Reply #20 on: December 22, 2018, 07:28:52 AM »
^^ sounds like what I did for a pipe on my it175j. For the end cap did you use the lid of a glass chutney jar?
Offline JungleBiker
« Reply #21 on: February 01, 2019, 06:58:05 PM »
     Ha!  No, I did that sort of thing when I was a kid, then found that it didn't hold up very well over the long term.  Now I have access to better tools and materials than I did now, so I actually made the end cap out of a piece of flat steel, I forget how thick it was, maybe 4mm?  The perforated sheet I used for the core was stainless.
       Interestingly, I found that the exhaust was significantly louder when the timing was retarded too far--my theory is that when the timing is retarded too far, less of the fuel-air charge has been burned by the time the exhaust port is uncovered, and more unburnt, burning gasses enter the pipe, possibly under high pressure and thus make more noise?  A louder "pop" per exhaust cycle, as it were.
--Badly abused 1982 Yamaha IT250J in the process of being resurrected.
--1967 Norton P11 (US project bike)
--1985 Armstrong MT500 (UK rider)
--1985 Honda XR600/628R (PNG daily rider)
-- lots of other junk spread across several US states and two big islands
