Author Topic: Leak down test  (Read 422 times)
Offline maw230
Leak down test
« on: March 10, 2018, 02:47:16 AM »
Hello,
Wanting to do a leak down test on my '86.  Do you guys have any recommendations on DIY and/or already made kits for this?
THanks
Re: Leak down test
« Reply #1 on: March 10, 2018, 09:28:16 AM »
I made my own for a DT200.
I made a plate out of 4mm aluminium bar to cover the exhaust and bolted it on with a rubber gasket made out of old inner tube, then made a plate to cover the inlet. I drilled and tapped two holes in the inlet plate to accept a schrader valve and an air pressure gauge like these:
http://www.ebay.com.au/itm/Water-and-Air-Pressure-Gauge-New-1-4-Brass-Thread-0-15-PSI-0-1-Bar-I5/182443077685?hash=item2a7a747035:m:mjejJBhwCKDy0MCHhuJEwlQ
http://www.ebay.com.au/itm/Schrader-Air-Control-Valve-1-8-BSPT-for-Compressors-and-Shock-Absorbers-Qty-1/322416165494?hash=item4b11804276:g:CrwAAOSwUKxYmarD
I bolted that on with a rubber gasket made out of inner tube.
I inflated the case to 6psi with a bicycle pump and checked for leaks with a spray bottle of soapy water and made sure the cases held pressure for a few minutes.
Re: Leak down test
« Reply #2 on: March 10, 2018, 05:51:15 PM »
It looks like this
Re: Leak down test
« Reply #3 on: March 11, 2018, 02:37:02 PM »
I made an adaptor to fit into the spark plug hole to fit a vacuum and pressure gauge alternatively, used an air fitting.
I put bungs into the inlet and exhaust made from rubber crutch tips. held them in with cable ties and rope. Put a bit of vaseline around the tapered part of the rubber to seal it.
Offline maw230
Re: Leak down test
« Reply #4 on: March 17, 2018, 02:36:34 AM »
Thanks guys.  Headed to hardware store after work.  Anyone know the inner diameter of the exhaust port off hand?
Re: Leak down test
« Reply #5 on: March 17, 2018, 07:34:33 AM »
Thats why I used a tapered rubber bung. Model independent.
