Author Topic: dt175 cylinder sleeve available??  (Read 684 times)
Offline twinrock
« on: October 31, 2017, 09:31:38 PM »
Does any one know if cylinder sleeves are available for the dt 18L ..maybe even it175 thanks..
Re: dt175 cylinder sleeve available??
« Reply #1 on: November 01, 2017, 11:20:38 AM »
You can get a whole new barrel and piston here:
http://www.ebay.com.au/itm/YAMAHA-DT175-CYLINDER-PISTON-RINGS-GASKETS-TOP-END-REBULD-KIT-DT-175-1986-2005/301290794951?epid=1430970704&hash=item462654afc7:g:5E4AAOSwdGFYo8sn
Just be warned though, they sent me a piston from an AG175 not a DT175, the AG has smaller windows in the skirt but I enlarged them with a dremel, and the barrels had a bunch of roughness in the castings in the ports that had to be smoothed out, and while I was at it I matched the transfer ports to the cases and knife edged the castings. Ended up being my best 175 to date.
If however you are considering putting this on a DT200 bottom end you are forbidden unless you add a skull headlight.
