Author Topic: JETTING Advice IT400D  (Read 514 times)
Offline ozadvntr
« on: October 30, 2017, 09:46:35 AM »
Hi all,
I am having issues with my IT400D leaning out at higher revs and running on. I am riding it mostly doing VMX at the moment and have been up and down on the needle and up on the main with no luck.
I intend on changing the needle and nozzle as the needle is slightly bent. I only discovered this yesterday.
Any successful specs appreciated including nozzle and needle recommendations as well as MJ size and Pilot Jet size.
Mick
IT400D, IT250G, IT200N
Re: JETTING Advice IT400D
« Reply #1 on: November 01, 2017, 07:17:34 AM »
First make sure your crank seals are good, no leaks around head gasket or base gasket and no cracks in the inlet manifold.
Is the ignition timing correct? Do you just have the one original head gasket?
Is it all still original IT400D; pipe, silencer, piston, air box cover?
What two stroke oil and ratio are you using?
Offline ozadvntr
« Reply #2 on: November 14, 2017, 08:04:25 PM »
Thanks for the reply.
Inlet manifold is fine, new one fitted. New base gasket and head gasket. Crank seals are fine.
Ignition timing is also good. One head gasket.
It has the original chamber but has a GMC silencer, not 12 months old. Piston is fine as are rings and bore. Great compression. Original airbox cover no damage.
Motul 800V at 40:1
Offline twohcrew
« Reply #3 on: May 15, 2019, 10:13:20 AM »
Have you checked your float height?
