Author Topic: New carb for my IT 200  (Read 858 times)
Offline Andrewv
« on: April 23, 2017, 12:54:15 PM »
Can somebody recommend a good but cheap carb I can purchase online for my 1984 IT200...
Thanks in advance...
Re: New carb for my IT 200
« Reply #1 on: April 24, 2017, 11:02:50 PM »
good and cheap rarely go together.
Mikuni or PWK all the way.
« Reply #2 on: April 25, 2017, 05:43:32 AM »
I've seen good condition Yamaha IT200 carbs for a fair price on US eBay.
Set-up your eBay search notifications and get bidding !
Why not use what Yamaha intended ?
Offline elsinorerider421
« Reply #3 on: April 25, 2017, 04:06:24 PM »
Funny I see your question-I played musical carbs out of boredom last week. I had a spare Keihin PJ 38mm laying around so I put it on my 1978 CR250. Huge difference! Since the CR ran so much better, feeling lucky, and never being afraid of a bit of a challenge, I put the Mikuni VM36 from the CR onto my 1986 IT200. I will admit I needed to treat the airboot to a blow dryer and push very hard into the intake boot. Also I had to be "creative" with the cable and the adjuster in the cap but it fits well and looks brilliant.  But more importantly, it hauls the mail now with no perceptible loss anywhere. I previously was considering selling the bike. Not any more. Definitely fun to ride!
Tom
Offline Andrewv
« Reply #4 on: April 26, 2017, 02:58:10 AM »
Thank you all for your suggestions....
I was thinking maybe I will throw my actual problem at you guys and maybe you would have a suggestion to replace a part and not the whole carb....
Basically while riding at a moderate speed, randomly the bike will just go FULL speed and backing off the throttle does not help... I have to pull in the clutch and hit the kill switch before I die...
I am pretty sure it is something with the carb BUT I am not experienced enough to diagnose it...
Any Ideas what would cause this?
Offline Kickaha
« Reply #5 on: April 26, 2017, 04:34:41 PM »
Carb slide or throttle cable is sticking or you have an air leak somewhere
Eat right
Stay fit
Die anyway
« Reply #6 on: April 26, 2017, 05:33:25 PM »
throttle cable crushed or catching on something?
Offline itdog
  • if i was blue i would dye
« Reply #7 on: April 27, 2017, 12:26:22 AM »
crank case seal....stator side
Offline esweetland
« Reply #8 on: April 27, 2017, 02:31:30 AM »
I would say that your problem is an issue that would not be fixed by a different or modern carb.
I would investigate your cable, crank seals and the condition of your stock carb first.
A larger or flat slide will not improve the performance of the bike if has other mechanical issues with the bike.
Offline esweetland
« Reply #9 on: April 29, 2017, 02:14:00 AM »
Opps
I meant to say that a modern carb will not fix the problem.
