Author Topic: Different Stators / Rotors on IT125  (Read 872 times)
Offline evh
« on: April 17, 2017, 03:22:45 AM »
Im rebuilding a 1980  it125 out of 2 bikes i have but they have different stator assemblies..
This one looks like the normal setup Ive seen on IT's
The second one looks different than what ive seen on these 125 and 175 engines..
any info to what that is?   did they change the 125's  or is that from a different engine like a yz ?
thanks
1980 IT 125
1982 IT 465
1985 Yamaha Tri-Moto 200 Yamahauler
1985 Honda CR500r
Offline DynoTronix
Re: Different Stators / Rotors on IT125
« Reply #1 on: April 17, 2017, 04:44:24 AM »
The first one looks like the right configuration for an IT125.  The second one might be a TZ125, which I believe uses a rotor instead of a flywheel.  What are the numbers stamped into the crankcase?
« Reply #2 on: April 17, 2017, 06:33:22 AM »
Looks like YZ125E / F to me:
« Reply #3 on: April 17, 2017, 09:39:59 AM »
What are the engine numbers?
What are you going to use the bike for? Do you need lights?
Offline evh
« Reply #4 on: April 17, 2017, 11:27:30 PM »
the bike will be used for casual riding..  I have my other 175's i used for technical track stuff and woods rides..
the engine numbers off the 125's are
3R9-004534  Small Rotor Engine
3R9-051304  engine with stock flywheel
1980 IT 125
1982 IT 465
1985 Honda CR500r
Offline DynoTronix
« Reply #5 on: April 18, 2017, 04:11:02 AM »
Based on what I'm seeing, it looks like both engines should have a flywheel.
« Reply #6 on: April 18, 2017, 09:00:13 AM »
Both engines are IT125.
If you need lights then use the flywheel.
What CDI boxes do you have?
Offline evh
« Reply #7 on: April 18, 2017, 10:44:42 AM »
Ill have to go and take some photos of each cdi..
Ill report back when i do
1980 IT 125
1982 IT 465
1985 Honda CR500r
Offline Rookie
« Reply #8 on: October 26, 2017, 06:58:30 AM »
Just a comment on the differences, the rotor setup doesn't provide much "flywheel" effect and will diminish the torque down low.  I have a YZ100 that had a flywheel that I converted back to a rotor and it really killed the bottom end, trade off is it seems to rev up quicker now.
Kirk
