Author Topic: IT200S added to Garage  (Read 11625 times)
Offline keny
Re: IT200S added to Garage
« Reply #60 on: November 26, 2018, 06:57:06 AM »
Well the PE I posted here + my 1987 Suzuki TS250X are gone, tradet them for a nice American 1981 IT465!
In Garage, Yamaha s: -83 IT175, -86 IT200, -81 IT465, -90 XT600Z,
Honda s: -97 CR125R, BMW: -11 R1200GS 30th edition
Offline keny
« Reply #61 on: January 27, 2019, 05:35:07 AM »
OK, time for an update.
Been working a bit now as then on the 200, and actually got it together!
Now yesterday evening I tried to start it first time after rebuild. did start 3rd kick, did run for 5 seconds and died, did not come alive, well for a few secons but still just running porly on low rpm even I had throttle fully open. Started backfire. Didi take plug off, soaking wet. So let it sat ower night and started test things. First ignition, and was way off, flywheel off and then came to this:
So probarly main reason then.....
« Reply #62 on: January 27, 2019, 07:59:46 AM »
The old 2 piece woodruff key in the flywheel on the IT200 trick. I've fallen for that a few times myself.
« Reply #63 on: February 03, 2019, 04:27:09 PM »
yep ..same here, also it can effect other bikes if there in the same area, like the IT175G
 ;D
« Reply #64 on: February 04, 2019, 07:36:05 AM »
I actually check and lap the flywheel to make sure it isnt going to do this. Easy enough to do, given the taper is what holds the flywheel and the key only locates it.
Offline keny
« Reply #65 on: March 20, 2019, 01:12:11 AM »
Finally running!
Offline keny
« Reply #66 on: March 21, 2019, 05:15:43 PM »
Offline keny
« Reply #67 on: March 24, 2019, 02:16:24 AM »
First real ride done today, bike did run great, just some fine tune needed, runs a bit rich in low range and hestigate as throttle opens, probarly just air scruve adjustment needed. Need to adjust rear brake pedal also lower.
Here a fev screen shots from my GoPro video, My son rides in front
« Reply #68 on: March 24, 2019, 08:40:43 PM »
Whats all that white stuff on the ground? 32 degrees science here today. AC on now.
Offline keny
« Reply #69 on: April 03, 2019, 10:15:46 PM »
Thats the stuff that brings a bit more challange in the riding  ;D
Getting warmer here to so less of it last weekend
http://youtu.be/UFQumTvyi1o
