Author Topic: yz 465 crankcase splitting  (Read 813 times)
Offline mars
« on: February 21, 2017, 09:58:20 PM »
hi guys
I'm based in the uk Staffordshire 52 years old and had 2 strokes a while now.my first off roader mind!!
got a rd 350lc 1982 and a 392 rz 350 1987 which is a 392 now putting out 75bhp and 44ftlbs 0f torque
this is my first post so be gentle!
ive got a 465 where the kickstart shaft fits in the crankcase its broke off
I'm going to get welded up if I can get the crankcases apart.the gear shift star seems to be the problem
how can I split the cases all bolts are out and have a 10mm gap between them all round
heres some pics of what I'm working with
Re: yz 465 crankcase splitting
« Reply #1 on: February 22, 2017, 08:05:07 PM »
That selector drum will go through the case, the points of the selector will go through the gaps. What case splitting tool are you using?
Offline mars
« Reply #2 on: February 24, 2017, 09:43:43 PM »
thanks for the reply
i attempted splitting with a large screw driver but gave up as i didn't want to damage the mating surfaces
was the best tool to use
regards
mars
« Reply #3 on: February 24, 2017, 11:19:47 PM »
here's my setup.. it's cheap and a little nasty but I've split countless engines with it.
I've seen members on here with nicer setups but I can't find the pics at the moment.
Offline mars
« Reply #4 on: February 25, 2017, 06:21:51 AM »
thanks for the pic really helpful ;D
so what is actually stopping the cases coming apart?
is it the webs on the crank?
mars
« Reply #5 on: February 25, 2017, 08:35:53 AM »
the fit of the bearings on the shaft and in the cases holds it together.
« Reply #6 on: March 01, 2017, 02:02:58 AM »
I use a automotive harmonic balancer puller. Looks like this. You'll need to use your own metric hardware.........at least in my case.
« Reply #7 on: March 01, 2017, 07:08:59 AM »
Heat is your friend,
Get a electric heat gun and heat up the cases, this will aid in making the cases split easier.
« Reply #8 on: March 01, 2017, 08:06:55 AM »
So will a few whacks with a soft dead blow hammer.
