Author Topic: Lubrication by YCLC system  (Read 1885 times)
Offline panpacific
« on: December 21, 2016, 11:36:03 PM »
The DT Lnza 230 is equipped with a lubrication by YCLC system in replacement of the former AUTOOLUBE
YCLS = Yamaha computer controlled lubrication system
"The lubrication system YAMAHA computer controlled (YCLS), depending on the speed of the engine with the help of an electronic control unit and a valve control of three-way"
See DT230 pump with 3-way control valve
http://www.fowlersparts.co.UK/parts/4156263/dt230-Lanza-4tp2-1998-010-c/2-stroke-oil-pump
http://www.fowlersparts.co.uk/main/img/assemblies/large/172cf8c965a37dccd04030aa0fb557c1.png
The autolube was an entirely mechanical system, the YCLS is a mix of mechanics and electronics
-the pump is always driven by the crankshaft (pinion)
-cable for the position of the accelerator but a TPS (Throttle Position Sensor) sensor on the carburetor?
-Flow is more regulated by the pump but by a valve controlled by the CDI
Do you have information about this system... reliability ?
A + Panpacific
Offline panpacific
Re: Lubrication by YCLC system
« Reply #1 on: December 23, 2016, 01:35:46 AM »
Photos :
« Reply #2 on: February 13, 2017, 07:27:21 PM »
   Hello there and welcome. The same line of thought has been used on the TZR 3XV9. I've never had one, but you can get more on the system by reading here: http://pure2strokespirit.net/forums/index.php?topic=1983.0 I don't know if you have to register to read!
