Author Topic: picked up a yz465 complete engine today  (Read 594 times)
Online storie585
« on: May 23, 2016, 11:24:19 AM »
well, i would like to say that it's a runner.. it's not. still worth the $50.00 I paid. crank is shot. it wasn't stored correctly. water in bottom end. I was able to clean up the cylinder , it's already 1st over. it will need boring to 2nd over to get it true. the ignition parts will work in my 490 but I'm not sure if the cylinder / head will interchange. can someone answer that question? the rest is pretty hammered. clutch basket grooved real bad and the case is broken behind the kickstarter. just a small piece missing, maybe it could be welded. clutch cover has a small crack in a wear mark, I suppose it could fix it with some epoxy in a pinch. i havnt split the case yet. does anyone know if any of the gears will interchange with a 490?
Re: picked up a yz465 complete engine today
« Reply #1 on: May 23, 2016, 12:59:24 PM »
Drive shaft is the same but main axle is different....some of the gears but not all are the same. Check yourself by clicking the part numbers....
http://www.partzilla.com/parts/search/Yamaha/Motorcycle/1980/YZ465G/TRANSMISSION/parts.html
« Reply #2 on: May 23, 2016, 06:09:01 PM »
You can swap the transmission as a complete assembly no dramas
Online storie585
« Reply #3 on: May 23, 2016, 08:53:13 PM »
ok thanks guys. i think my next plan is to submerse the entire bottom end in a bucket of kerosene until i get to it...  ;D..
