Author Topic: IT' s the ugly stick IT200S restoration  (Read 5866 times)
Offline high voltage
Re: IT' s the ugly stick IT200S restoration
« Reply #40 on: August 18, 2015, 08:44:23 PM »
I just went through bigshorts build and it appears he has used the bullet connectors for the rest of the wires..
reason I am asking is I am going to order connectors etc and need to know which ones I need ..
I suppose I could just make it up as I go....
« Reply #41 on: August 18, 2015, 09:10:32 PM »
Your manual has the male and female ends depicted in the wiring diagram along with the block connectors.
« Reply #42 on: August 18, 2015, 09:57:44 PM »
ok thanks chris
didnt think of that!
I seem to be missing a 4 terminal block ..
the others are bullets  ..
« Reply #43 on: August 19, 2015, 07:46:07 AM »
I'll see if I can get a photo of mine if it helps.
« Reply #44 on: August 19, 2015, 12:28:58 PM »
yes thanks
I have a the TT350 one which has a 4 pin plug in attached ...it has both male and female ends so I should be able to use that..
Offline sluggish7
« Reply #45 on: August 19, 2015, 07:06:56 PM »
Are these the pictures you want ?
This is an original harness which David copied
Ignore the wire colours to the indicators they are off a Husaberg 650
1x IT 400,worn out now
1x IT 200
3x IT 250 Various
1x Gas Gas 200 excellent
1x GS650 project
1x IT 125
1x It 465 working on it
1 x IT 175
And a sh_t load of bits
« Reply #46 on: August 20, 2015, 02:16:28 PM »
yep,  that's what I'm after
It shows the two 4 pin blocks  ,one black one white .
the black one I am missing ...I will just use the white one off the TT switch block
thanks for that ..
« Reply #47 on: August 20, 2015, 04:42:29 PM »
Those black ones are no where near as robust as the white ones....when kept out of the sun.
....gee, treading lightly there....  :-X
« Reply #48 on: August 20, 2015, 05:27:20 PM »
mine is a little different as i used an aftermarket switch block, however all the above information is true and correct, connectors are in the manual you can source them however your better off using what is most robust rather than original and my only other advice is get the right gauge wire. just finished putting a 6v horn on the 175, works a treat
Shorts
Offline sluggish7
« Reply #49 on: August 20, 2015, 05:33:31 PM »
Mmmmmh and what a lovely 175 David
1x IT 200
3x IT 250 Various
1x GS650 project
1x IT 125
1 x IT 175
