Author Topic: IT200 engine bolt size, lengths, and quantity.  (Read 4314 times)
Re: IT200 engine bolt size, lengths, and quantity.
« Reply #10 on: May 29, 2014, 05:34:58 AM »
Stainless bolts are good for producing fake ' works ' looking items.
Take one boring old Low Head M6 stainless bolt :
Quick spin in the lathe :
Or as used on the Yamaha YZM500:
Online sweede490
« Reply #11 on: May 29, 2014, 08:32:23 AM »
Just s tip ..
   Always use copper coat or res-Q steel on the threads
   Of stainless bolts being used with aluminium or
   Magnesium , or you will have corrosion issues
     One of first things you learn when building alloy boats
     Muzz
Offline Zrt1200
« Reply #12 on: May 29, 2014, 11:46:49 AM »
Just s tip ..
     Muzz
Muzz, I work in a mold shop and seen first hand the difference from steel bolts VS Stainless steel bolts in aluminum after 10 years of service. The steel bolts we have to drill every one out as they just snap off from all the corrosion. There are like part of the aluminum. The stainless bolts come out with out breaking at all. Al
Current bikes, (82) IT465J, (85) IT200N, (05) GasGas 200, (11) DRZ400S, More photos can be found at.....
http://s582.photobucket.com/user/Zrt1107/library/dirt%20bikes?sort=3&page=1
« Reply #13 on: May 29, 2014, 03:48:06 PM »
I knew there was something that needed to be applied to stop the "welding" by corrosion....thanks Muzz.
Offline stainlesscycle2
« Reply #14 on: June 12, 2014, 11:37:11 AM »
as long as you are not in a saltwater environment, there should be no issues with stainless in aluminum.   anti seize is recommended of course...
Offline Zrt1200
« Reply #15 on: July 17, 2017, 10:55:08 PM »
Here is the original pic I had posted Photobucket.
