Author Topic: IT200 Bearings - Non Genuine  (Read 9327 times)
Re: IT200 Bearings - Non Genuine
« Reply #10 on: May 03, 2014, 05:40:53 AM »
Be wary with the crank seals stainless, as most of the crank seals I have replaced have been teflon lines on the inside, i.e on the side closes to the crank cheeks. They arent a standard seal. That might account for the double lips.
Offline stainlesscycle2
« Reply #11 on: May 03, 2014, 06:37:14 AM »
a standard double lip i.e. adl/tc/hmsa7 etc. in nbr or viton is more than enough to deal with the environment.  i do not know why yamaha specs sd, it's a low/medium pressure seal, that isn't doing anything special, there's not a particularly high runout.   as i said, if you put 2 2 32x44x4 back to back, you get 2 seals, and 2 dust wipers.  it's not the best way for sure.  it's a moot point, i don't believe 32x44x4 exists anyways..
very few manufacturers use a crank seal that is not available off the shelf.
anyways, i was just putting the seal numbers out there - i use yamaha seal for wet side.  ignition side (and every other seal on the motor) i use aftermarket.
« Reply #12 on: May 03, 2014, 07:32:13 AM »
Sounds like you have a lot more experience with this stuff than I, so thank you .
Offline kiwiandy
« Reply #13 on: February 03, 2016, 07:05:14 PM »
I see this thread is a couple of years old now, but still seems to have a lot of info missing.
I looking at rebuilding the rear suspension and shock on my 85 IT200N.
Looking at the parts list and  exploded parts diagrams there appears to be a truck load of expensive (at Bike Bandit prices... I guess thats why they are called bandits?) bearings and seals.
Any recommendations for an easy way to go here?
I can seems to see any detailed listing for alternatives?.. is the only option to buy OEM?
My present repetoire: YZ250A, YZ250B, TY250B, YZ125X, IT175J, DT175G, TT500E, TT500G, HL500, YZ465G, IT465H, YZ250K, YZ250N, YZ125N, 2 x IT200N, PW50, YZ250FX H,  and lots of other non YamaBikes..
« Reply #14 on: February 03, 2016, 07:53:56 PM »
Hi Kiwi,
All balls do a linkage set for the IT490K,fits the IT200.
As far as your shock goes,the body is probably f___ked internally,but most dealers just re gas + oil + seals.
I have had new shock bodies machined up and shafts re chromed,but very expensive.
« Reply #15 on: February 03, 2016, 10:29:48 PM »
And the eye spherical bearings are the same as the YZ125L as well apparently. Search for yz125 and bearing or similar and someone has posted the part numbers for all balls kits.
Offline kiwiandy
« Reply #16 on: February 04, 2016, 06:10:20 PM »
Hi Kiwi,
Thanks Steve, so far the shock body looks ok, My suspension guy has recommended using an alternative seal, so will see how that goes .
Searching 1983 It490 (and 1985 IT200) both got zero results on the Allballsracing.com website??
Offline kiwiandy
« Reply #17 on: February 04, 2016, 06:27:17 PM »
My searching skills dont seem to be up to scratch today... I searched this forum and YZ125 forum and cannot find anything about this. Also google couldnt find anything either.
Offline kiwiandy
