Author Topic: Same heads?  (Read 718 times)
Offline Dave Walker
Same heads?
« on: November 03, 2013, 01:11:20 AM »
I don't know if I'm on the right board, as there seems to be a cross over on this point - Do the WR200 & DT200WR share the same engine top 1/2
( head , cylinder  piston rings, pin small end, gaskets )? Do they share the same model prefix - 3XP?
  And finally, can you give me the years of manufacture for both models? - TIA
Offline gearhead86
Re: Same heads?
« Reply #1 on: November 03, 2013, 01:59:48 AM »
I cant answer most of your questions but i know of one differnce and that is autolube on the DT200WR and premix on the WR200 otherwise i believe the engine is the same. Someone correct me if i'm wrong please.
Just fyi, the Canadian DT200R's engine is not the same as a DT200WR's. biggest differnce is the DT200WR is case reed induction and our DT200R is piston port reed induction.
Eldon
I'm from Canada eh.
