Author Topic: Alloy rear sprockets  (Read 2110 times)
Offline misfit
« on: July 05, 2013, 09:58:59 PM »
Does anyone know where you can get original type alloy rear sprockets?
Re: Alloy rear sprockets
« Reply #1 on: July 05, 2013, 10:43:56 PM »
I've only seen independent manufacturer's who make billet alloy ones with a bonded steel cog ring on ebay...stupid expensive though..,..more bling than practical. Perhaps Solo Speedway specialists....
Offline Adelaideit
« Reply #2 on: July 05, 2013, 11:37:23 PM »
I wondered about alloy versus steel sprockets with weight saving. A poop before a ride would have the same effect as a alloy sprocket. :D
« Reply #3 on: July 06, 2013, 02:41:33 AM »
   Couldn't agree more, not to mention how easy alloy sprockets bend and wear! I had Renthal rear sprockets twice on my WR200 and I'll never do it again. It just isn't worth the money and the difference in weight is not huge. From what I saw Afam makes aluminum (7075 T6) sprockets for all the IT range apart from the 400. But it does for DT400. Maybe just not into the catalogue, yet similar to another model. I am sure Renthal has some compatible too.
Check http://www.renthal.com/home.asp and http://www.afam.com/html/product-catalogue/index.html
« Reply #4 on: July 06, 2013, 05:23:58 AM »
I wondered about alloy versus steel sprockets with weight saving. A poop before a ride would have the same effect as a alloy sprocket. Cheesy
Very true !
However, I've still got those lovely aircraft alloy Allen screws I bought 25 Years ago. Been waiting for the perfect bike to use them on !
Weight saving...... 100 grams if I'm lucky !
Offline misfit
« Reply #5 on: July 06, 2013, 09:15:07 AM »
I'm not so much interested in finding alloy sprockets, more so finding one that has six holes in it like the originals. Most of the sprockets you find have got triangle shapes cut into them
Offline tymes
« Reply #7 on: July 06, 2013, 08:05:33 PM »
I have an AFAM alloy sprocket on my TT, I have been very impressed by the wear, or lack of. The sprocket also looks like a steel one so it looks very original. The idea of weight saving means little in the overall scope of things as bike and me are like more than a quarter of a ton and thats at my ideal race weight of 120kgs even after a poo.
I also use normal tubes,  I haven't found any more punctures using them either.
But the weight savings on your wheels (however small that may be) add up to less unsprung weight. Not that I really go hard enough for it to matter but nothing kills an enduro bikes suspension handling like unsprung weight.
Offline oldbiker
« Reply #8 on: July 06, 2013, 08:59:32 PM »
misfit, Ive just fitted new sprockets and chain to my Ty250, Im not sure what brand it is, but they will last and they fit easy enough. (6 bolts mounting)
Ill sus them out tomorrow and get a pic for you tomorrow.
Stand up you fool!
Offline misfit
« Reply #9 on: July 06, 2013, 09:02:06 PM »
That would be good mate. All I'm really after is a sprocket that looks just like the original one.
