do you think it can be done to a 490...more so would it be a similar task or more complex?
You could do it to a 490 and it would be pretty much the same as what I had to do on the 175.
Either YSS PD Valves or Race Tech Gold Valve Emulators could be used and the procedure would be the same.
Only the 76-78 C, D and E models are trickier because they need an extra adapter.
For 77-78 D and E model 250 and 400 I think you can fit IT175F damper rods and only lose 5mm travel.
It was easy to find bent or rusty IT175F forks cheap to donate the damper rods.
I'll try it with my IT250D and add the pics to this thread.
Hold back on ordering yours until you can measure your forks Griffo.
The YSS and Race Tech recommendations need to be confirmed because they have not always been 100% accurate.
It may just be the earlier models that they are out for. I know with my Yamaha road bikes that the earlier ones have thicker tubes.
It is best to measure the diameter of the damper rod piston but that involves stripping the forks.
It should be close to the diameter of your springs. Can you measure that for us Griffo and itsa490 please.
Graeme and Dave are going to measure theirs (IT175G and IT200L).
How about you Jock? Can you measure the IT125 spring diameter?
