Author Topic: Gear ratios  (Read 846 times)
Offline basketcase
Gear ratios
« on: April 30, 2012, 03:05:06 PM »
Guys I have a gearbox here that was sold as a IT465 Box, however on closer inspection it appears to be from an earlier Yamaha. I hazard a guess to say the seller mistook the 425 for a 465? The second pinion gear is retained by a circlip and there is an oiling hole in the input spindle. If there is someone out there with a 425 gearbox in bits, perhaps you would be kind enough to count the teeth and let me know so I can identify which box I have got here.
Re: Gear ratios
« Reply #1 on: April 30, 2012, 06:13:57 PM »
The 425G shares cogs, washers and clips from earlier models, both IT and YZ....
http://www.boats.net/parts/search/Yamaha/Motorcycle/1980/IT425G/TRANSMISSION/parts.html
But my Clymer's doesn't give internal ratios to help work it out unfortunately.
Offline basketcase
Re: Gear ratios
« Reply #2 on: May 01, 2012, 07:26:21 AM »
Thanks for the link there, I recall seeing some diagrams like this which have the gear tooth count next to the part number. That would be gold. Yes I see what you mean, comparing the Early DT,MX and YZ boxes to the one I have is proving to worsen my predicament! Now I am sure that this could be from just about any late 70's Yamaha, which narrows it down to about half a dozen models ??? ???
Re: Gear ratios
« Reply #3 on: May 01, 2012, 07:34:45 AM »
I was hoping the part numbers can shed some light like the bolt numbers do (length is part of the part number in mm)
I am sure I have seen gear ratios for my IT250 (ie; 6th 2.075: 1. 5th 3.75:1 etc....)
Cheers.
